Configure an IS-IS accept policy for a specific I-SID number to represent a local or remote Layer 3 VSN, which allows the system to redistribute the remote VSN to the VSN where you applied the filter. An I-SID value of 0 represents the global routing table (GRT).
If the route policy changes, you must re-apply the IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map to apply.
- Select IS-IS.
- Select the Accept Isid tab.
- Select Insert.
- In the Isid field, specify the SPBM nickname.
- Select enable in the Enable check box to enable the filter.
- In the PolicyName field, specify the route-map name.
- Select Insert.
Accept Isid Field Descriptions
Use the data in the following table to use the Accept Isid tab.
Name |
Description |
Isid |
Configures a specific I-SID number to represent a local or remote Layer 3 VSN to which the IS-IS accept policy applies. Based on the routing policy the system applies, the system redistributes the remote VSN to the VSN where you applied the filter. An I-SID value of 0 represents the global routing table (GRT). |
Enable |
Enables or disables the I-SID entry. You must enable the value to filter. The default is disabled. |
PolicyName |
Specifies the route map name. You must configure a policy earlier in a separate procedure. |
BackbonePolicyName |
Specifies the backbone route map name. You must configure a policy earlier in a separate procedure. |
